Firefox crashes on startup. Glib-GObject-WARNING **: type name `GtkScrolledWindo/u007f'
  • 4 views
  • Last reply by John99
[user@durrell ~]$ firefox
(firefox:2698): GLib-GObject-WARNING **: type name `GtkScrolledWindo\u007f' contains invalid characters
(firefox:2698): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed
(firefox:2698): GLib-GObject-CRITICAL **: g_object_new: assertion `G_TYPE_IS_OBJECT (object_type)' failed
(firefox:2698): Gtk-CRITICAL **: IA__gtk_container_add: assertion `GTK_IS_WIDGET (widget)' failed
(firefox:2698): Gtk-CRITICAL **: IA__gtk_widget_realize: assertion `GTK_IS_WIDGET (widget)' failed
(firefox:2698): GLib-GObject-CRITICAL **: g_object_set_data: assertion `G_IS_OBJECT (object)' failed
(firefox:2698): Gtk-CRITICAL **: IA__gtk_widget_set_direction: assertion `GTK_IS_WIDGET (widget)' failed [user@durrell ~]$ (crashreporter:2733): GLib-GObject-WARNING **: type name `GtkScrolledWindo\u007f' contains invalid characters
(crashreporter:2733): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed
(crashreporter:2733): GLib-GObject-CRITICAL **: g_object_new: assertion `G_TYPE_IS_OBJECT (object_type)' failed
(crashreporter:2733): Gtk-CRITICAL **: IA__gtk_container_add: assertion `GTK_IS_WIDGET (widget)' failed
[user@durrell ~]$ firefox (firefox:2698): GLib-GObject-WARNING **: type name `GtkScrolledWindo\u007f' contains invalid characters (firefox:2698): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed (firefox:2698): GLib-GObject-CRITICAL **: g_object_new: assertion `G_TYPE_IS_OBJECT (object_type)' failed (firefox:2698): Gtk-CRITICAL **: IA__gtk_container_add: assertion `GTK_IS_WIDGET (widget)' failed (firefox:2698): Gtk-CRITICAL **: IA__gtk_widget_realize: assertion `GTK_IS_WIDGET (widget)' failed (firefox:2698): GLib-GObject-CRITICAL **: g_object_set_data: assertion `G_IS_OBJECT (object)' failed (firefox:2698): Gtk-CRITICAL **: IA__gtk_widget_set_direction: assertion `GTK_IS_WIDGET (widget)' failed [user@durrell ~]$ (crashreporter:2733): GLib-GObject-WARNING **: type name `GtkScrolledWindo\u007f' contains invalid characters (crashreporter:2733): GLib-CRITICAL **: g_once_init_leave: assertion `initialization_value != 0' failed (crashreporter:2733): GLib-GObject-CRITICAL **: g_object_new: assertion `G_TYPE_IS_OBJECT (object_type)' failed (crashreporter:2733): Gtk-CRITICAL **: IA__gtk_container_add: assertion `GTK_IS_WIDGET (widget)' failed
Are you able to get the crash ID s that firefox generates. These should be available on your sytem, and if necessary may be submitted using an alternative browser.
See firefox crashes
